Valve is leaking but I don’t know what to do!! Any suggestions??
Turn the inlet 1/4 turn valve off and open the test valve petcock to relieve the pressure in the backflow preventer. The leak should stop. Close the test valve and then slowly open the inlet valve. There may be a gushing water out the top of the back flow preventer until the diaphragm sets. That might push any debris out. If not, then you need a rebuild kit or the back flow prevent has to be replaced.
Reactions: x Wild Bill x
