- May 2, 2017
- 104
- Plaster
- Hayward Aqua Rite (T-9)
I currently have a 3/4 HP pump with a suction cleaner attached directly at the skimmer (just moved so equipment in sig is wrong) also have a Skim A Round skimmer attached between the skimmer and cleaner. Problem is, not quite enough suction to run both....so once a week before work I turn skimmer off so cleaner can do it's job.
The pool has a capped off what I believe was a line for a booster pump. I am about to replace all pad equipment but not sure best route to go. Also the main drain line is shut off to divert all suction to skimmer.
New equipment includes Pentair Superflo VS pump, Pentair Clean and Clear 200 Filter, Aquarite SWG.
1. Keep plumbing as is and hope pump can run cleaner and skimmer from skimmer suction line.
Not sure if below two are possible or advisable
2. Plumb in capped off line to suction side and using a valve with timer divert suction couple hours a day to dedicated line and otherwise pool runs as normal.
3. Plumb in capped off line to pressure side and using a valve with timer divert water going back to pool couple hours a day to dedicated line to run a pressure driven cleaner
