Hi all,
I am a new pool owner and have been reading the TFP for sometime now. We just opened for this year (pool was winterized in Oct 2021).
Pool has been cleaned, vacuumed and brushed. Filters have been hosed and cleaned (Pentair cartridge filters). However, I am observing that the FC goes to 0 very quickly.
Here are the results from TF 100
FC 0
Cc 0.5
CH 550
TA 110
Ph 7.6
Cya 40
Based on these, I SLAMd the pool to 16 PPM FC and did an OCLT. The FC dropped to 8 PPM next AM. The pool water appears slightly cloudy (hasn’t been crystal clear since I opened this year).
My plan is to continue with the SLAM till OCLT indicates 0 loss and water is clear.
I also plan to clean my filters again as the back pressure on them is 25 Psi, which is higher than normal (15-18psi).
Is there anything else that I should be mindful of? Is it common to use lot of FC at the start of a new season? I don’t see any green algae in pool.
Thanks for all your help!
FC 0
Cc 0.5
CH 550
TA 110
Ph 7.6
Cya 40
