I would like to replace my existing pool pump with a new single speed pool pump and run off solar panels.
To run off solar power, I need to replace my pool pump with a DC pool pump or switch to a 110V pool pump with an inverter. The DC pool pump may work, but then means I could not run my spa at night. Instead I am thinking of swapping out my 2.5HP Jandy pump with a pump that runs using 110V because its not really feasible to run a pool pump off solar using 220V. With this setup, I could add a switch that would let me power the pump using the solar panels or switch to running off AC at night. Jandy makes a VS pump that runs off 110V, but given I will be running off solar power, not sure I need a VS pump.
I estimate I pay between $30 and $50 per month to run the pump. My current pump is old so will need a replacement sooner than later. The cost of the panels would be about $1600 plus the inverter. Maybe it is better to just keep using AC only and go with a VS pump for about $1800.
Has anyone here done this before? What was your experience? What do you recommend?
