- May 31, 2012
- 854
- Vinyl
- Jandy Aquapure 1400
Last year I switched my pool heater to a Raypak R266A. I appear to have the millivolt version rather than the digital version I want to use my Home Automation system (Control4) to flip a relay to turn the heater on and off. (I will also use a relay to control the pump but that is a different issue).
This heater has a fireman's switch and also three wires for remote control. On a bundle of three wires it says 'WHERE NECESSARY ADD"POOL/SPA REMOTE" SWITCH HERE'.
In the manual it says
So the way I plan to do this is to connect a relay between the Pool common (Black/Orange) and the 24VAC Hot (Blue). When the circuit is Open then the heater will be off, when it is closed it will be on. Is that the correct way to do it? When I have the system set up in this way can I still adjust the temperature or is the heater assuming that a remote control will do this?
it sa
The heaters are equipped with the ability to work with external remote controls. The supplied 7-pin remote wiring connector supplies power out to either a toggle switch or the switch contacts of a third-party remote. The remote works by either making or breaking the circuit created by the remote wiring. Typically, a remote does not supply power to the heater, it only provides a switching function to turn the heater On or Off.
it sa
