Years of using the tri-chlor hockey pucks for sanitizer left me with a very high CYA (180+) and a recurring algae issue. Last year I abandoned the pucks and switched to liquid chlorine... without much difference. This year I'm trying calcium hypochlorite... partly because I can get it delivered -- I have to go out for the liquid chlorine. So far, so good -- I've been open for a month and the water is crystal clear. I add a pound of cal hypochlorite every two or three days and I test the water regularly. A pound moves the chlorine up to 10 - 11 ppm and then it fades to about 5 ppm after a couple of days. CYA is down to about 100.
I sprinkle the dry product along the edge of the pool when I apply it.
Are there any issues I should be aware of using this method? Would it be better to add the cal hypo directly to the skimmer while the filter is running to avoid potential bleaching issues with my liner?
I believe my signature has my pool specifics, but if not, it's a 20,000 gal inground with a vinyl liner in southern Maine.
