Moved from here.
Tagging on to this thread just due to similar issue and my confusion.
TA is sitting stable at 80 but PH keeps climbing quickly after I reduce with MA.
My confusion comes from TF100 recommended TA levels between 100 - 120 and pool school recommended 50-90.
I'm either on the low end for one or the higher end for the other, and as I understand it either end can cause PH fluctuations.
Not sure which direction I should be pushing TA to help stabilize PH. (or possibly some other factor I'm not thinking about)
Pool is clean and clear, and FC easy to manage.
Your thoughts would be appreciated.
