Hi all,
Just joined but think I'll be active as im installing a 15ft round gre steel wall agp. Dug about 30cm on the low side, bit more on the higher. Digging was very difficult as ground got extremely rocky. Put the walls up, no water yet, and realized one side is about 1.5 inches lower. Taking the thing out and digging deeper isn't a possibility. Should I lift up the walls and throw some dirt under the low side? Or will that just cause more potential problems and this much tilt is ok?
Thank you for your opinion,
Richard
Richard
