Pool is a little over a month old. I started up the SWG yesterday. I've never used a SWG before and want to make sure I have done everything correctly and it is working as it is suppose to.
Added salt to pool (goal was to get it to 3000 - I'm close, will check again tonight) on 07/20/15 at about 1600
Using K1766 Salt Test Kit by Taylor.
I plugged in the TCell to the OmniLogic.
My Pool filter pump currently operates from 0800-1700 daily. I scheduled the SWG to do the same.
I looked at the diagnostics on the OmniLogic screen and later on at the diagnostics screen on the Android App.
It would be super helpful if someone could explain what each entry on the screen indicates and what I should be looking for in regards to each entry. Or is there some literature from Hayward which explains this stuff? There was nothing in the OmniLogic instructions that I could find and zero instructions were in the box with the TCell.
Attached are what I observed.
These two pics are from the OmniLogic screen shortly after I started the SWG
07/20/15 at 2015
07/20/15 at 2017
Then here are two screen shots from my android app:
07/21/15 at 0158
07/21/15 at 0752
07/21/15 at 1637
Thanks for any help.
07/20/15 at 2015
07/20/15 at 2017
07/21/15 at 0158
07/21/15 at 0752
07/21/15 at 1637
