I’ve broken the o ring lip on my SWG coupler twice now due to worn o rings and/or over tightening. And rather than cutting out the exiting PVC plumbing and joining new pieces as the coupler ends for the SWG are glued on, I’ve devised a successful method of uncoupling the piece and just gluing on the new coupler.
1. Using a heat gun I soften the PVC coupler in one spot and peal up and expose the male PVC pipe the coupler is glued to.
2. I then work the heat gun around while prying up the softened coupler all the way around until all coupler material is removed.
3. Using 80, 150, and 300 grit sandpaper I sand the surface clean and ensure a proper fit for the new coupler.
4. Primer and glue the new coupler to the existing male PVC pipe.
5. Check for leaks.
Hope this helps anyone!
5. Check for leaks.
