unable to control temp from iphone using screenlogic
ajw22
41,320
Northern NJ
Pentair Intellichlor IC-60
While we are on this topic, is there a way to calibrate the spa temp? I see only pool and air in the setup. Thanks.
You see AIR and WATER in the setup.
WATER reads pool temp when in POOL mode and spa temp when in SPA mode. The calibration applies to both as the temp information comes from the same temperature sensor point in your plumbing.
