Hi All - like the title says, we have 2 umbrella sleeves in the concrete pool deck. This was the 4th winter and both of them somehow got water in them, froze and the top part of the sleeve popped up and was laying beside the pool.
Not sure how they were installed - which means I'm not sure how water got in there (we have the threaded caps on during winter). I THOUGHT the concrete formed a seal on the top, but I guess not....
Both of them look like they came in 2 pieces? Where they separated, it is 'clean' (and at the same spot)
Questions:
1. How would you repair this? I'm sure I can use a PVC glue to hold the top back in place with the base that is still embedded in the concrete, but what about sealing it so this doesn't happen again
2. Has anyone had luck with a caulk that doesn't look terrible when combined with concrete? I was thinking that if I PVC glue it back together, I would caulk around the edges?
Thanks, Kevin
Questions:
Thanks, Kevin
