Perfect. That’s basically the same as I bought I think.
I think the plastic looks cleaner and one less thing to be bonded. Plus, don’t you have to sleeve the brass one for an umbrella to fit? I saw ID was 1.9”??
I think, if I understand what I am googling, the 1.9” is standard diameter for game poles (volleyball / basketball). You can slide a piece of 1.5” PVC (1.9” OD & 1.5” ID) into the sleeve and use the brass sleeve for an umbrella.
So, I think I may do two of these sleeves in the volleyball spots on either side of the pool and use the plastic ones where we will will be only utilizing umbrellas.
