- Dec 25, 2021
- 91
- Plaster
- Pentair Intellichlor IC-40
Good day. I was able to snag an ultra temp from one of my job sites a while back. It took quite a while but I finally got the wiring and plumbing in.
YAY! the heater works on manual mode. What I mean by manual mode is I can go to the control panel of the ultra temp and turn it on/off. The problem I have is I don't have the cable that was connected to the heater previously. Luckily there was a pigtail hanging from the Ultra Temp that was clipped off which was a 4 wire cable but only 2 low voltage wires were connected. How can I hook up that pigtail to my intellicenter (assuming I have the length)? I read some of the ultra temp manual and it refers to a RS 485 connector. This, I do not have--should I order one or would I be able to wire it differently and have the capability for the intellicenter to control the heater? What are my options?
Thank you in advance
