Hello,
I have recently installed screen logic on an easytouch 2 4p system. I was hoping to control our newly installed Ultratemp 120q. I have everything wired up and our ultratemp is set to remote rs485. I have configured the screen logic as "solar, solar using heat pump, and ultratemp" clicked on page 3 of 5. On the main screen I'm getting heat mode as heat pump only but it saying "pool heat status: off" and the heat pump will not come on despite setting desired temp above current pool temp. The ultratemp screen has a "heartbeat" asterix and is on, but stating "pool idle" so not sure what to make of that.
I'm not sure if I have to setup a specific heat circuit or if somehow I've messed things up. Originally my pool (no spa) had a spa circuit and I'm not sure why. I have moved the spa circuit to not used. We only have a pool with a booster pump cleaner and a light. Not very complicated. We now have pool circuit and cleaner circuit. Not sure if I'm explaining this correctly. I've attached screen shots.
Help!
Help!
