I have a two year old (only two years old!) Century two speed 1 hp motor w/timer hooked up to my 11,500 gal pool with SWG. Everything's been fine until a few days ago I noticed the high speed wasn't working.
I pulled the motor from pump and replaced the start capacitor with an exact replacement. Tested it before installing back in pump and no change. The low speed starts just fine but the high speed (normal speed) will hum and then the
motor shuts off. I discovered that if I turn the impeller by hand to give assist for high speed, it will then start and run just fine. I did try one more start cap just to make sure I didn't get a bad one but still the same issue. I'm considering opening timer box which sits on top of motor to see if there's a relay or loose wire inside. I'll have to get a security torx bit to do that. 1 hp 2-Speed 56J Frame 230V Pool Motor with Timer Century # B2975T
I would appreciate any other advise/suggestions for this problem. Thanks!
