Hello all - my inground pool and spa is new as of July 2022. This issue has been present since the beginning, but I haven't really looked into until now.
The spa has six jets. Four of them work as you would expect. The other two push out a lot of water but they don't aerate and bubble like they are supposed to.
I have observed a few things that may or may not have anything to do with the problem:
I have finally gotten around to mentioning to the pool builder and they are coming out to look tomorrow, but I don't have a high degree of confidence they will find a solution, so wondering if there's anything I might suggest.
- As mentioned, water flows fine through these. In fact, I would say they have even stronger flow than the other jets that are aerating.
- The tip of jets on these two seem to be closer to the ends of their outlets into the spa. In general, it seems the farther back the jet is from the end of the pipe, the more it aerates.
- Perhaps most interestingly, I can actually get them to aerate and bubble by inserting my finger part way into the pipe and blocking part of the flow. It's like a switch. I put my finger in and it immediately starts. I remove my finger and it abruptly stops. I made a little video of this tonight in case that helps.
