- Apr 10, 2018
- 5,204
- Plaster
- CircuPool RJ-45
I'm thinking about reconfiguring my plumbing. I currently have an Intelliflo VS connected to the pool plumbing and separate 2 HP Whisperflo single speed pump connected to the slide/waterfall combo. I want to integrate the two systems and do away with the Whisperflo. I would also like to convert the dual (VGBA) slide intake/suction ports to pool returns to enhance skimming action over the tanning ledge. Hard as it to believe, the there is only one 1 1/2" return for the entire pool.
Photos of the pad and the intakes are shown below. I plan on splitting the current single return with a 3-way diverter valve sending one port to the slide return and one port back to the pool return. I plan to split the pool return again to provide the ability to balance the main return and new dual returns next to the tanning ledge. Should I use a 2-way or 3-way valve between the main pool return and the new returns. I'm thinking a 2-way should work (and would be easiest to install)?
The current slide intake ports are 2" diameter and are located low on the side wall. I need to convert at least one of those into a 90 degree return to push water up and along the wall. I believe I've found the parts necessary to make the conversion.
Any comments or suggestions are appreciated.
