- May 11, 2023
- 22
- Fiberglass
- Jandy Aquapure 700
I had been using the pH test block that came with the TF Testkit but ended up getting a Taylor test block. I wanted to compare the results between the two thinking they would be identical. In the pic attached I would read the Taylor block at 7.2, whereas in the TF test block more like 7.8. I took the samples at the same time with the same arm scooping up the water. The Taylor uses the R-0004 solution where as the TF uses the R-0014. Both tests had the sample as the same color, just the scale is different. It could explain why I kept having to dump acid in the pool to keep the pH down, because it was really getting down to 6.x rather than mid/upper 7. Did the color of the TF block just fade?
