Two cents from a newbie... The drops need to fully form before falling in. The bottle should be straight up and down while you squeeze gently, allowing about one drop per second, swirling the sample while adding drops. At first, it feels like rubbing your stomach and patting your head! (hence the benefit of a magnetic stirrer). As the pink fades, you can slow down a little so the sample mixes fully.
It's often mentioned here that static charges can affect drop size, and this can be eliminated by wiping the tip with a damp tissue between drops. Fortunately I haven't seen this because I would need a third hand or a magnetic stirrer.
Reading the "Notes" section at the bottom of
Pool School - FAS-DPD Chlorine Test will boost your confidence in the test.
There's way better experts here to explain this, but also from a newbie who's been through it, while 14.5-17 is more than you need, it's not
super high. If your water was warm enough, it would be safe to swim up to the shock level that is correct for your CYA level. With CYA at 50 or 60, your shock level would be 20-24. That said, I'd rinse my cossie (swimsuit) and take a shower after. After swimming in FC 24 / CYA 60, I could smell chloramines a little on my skin after. Not dangerous or anything - just annoying. I hope my comments are helpful, and welcome, you've found an amazing forum!
