Hi Everyone,
I'm a first-time pool owner but grew up helping my dad with pool maintenance and house sitting neighboring swimming pools in vacation time.
It did not prepare me for my current challenge. I took ownership about 6weeks ago of a pool after moving into new house and I'm desperate for advice on what to do next.
Tried for three weeks to clear pool of green algae with no apparent effect. Water condition is a cloudy bright green color at the moment. Can't see my hand when I take a water sample. It all got worse after several days of heavy rain and thunder three weeks ago. The water clarity before the rain started was already cloudy with algae present.
This afternoons water sample test at the local pool maintenance shop shows:
FC - 0.9 ppm
TC - 1.2 ppm
PH - 6.9
TA - 80
CH - 550
CYA - 55
FC, PH and TA corresponds to my home test kit results
I've tried to shock the pool with 4x maintenance dose of chlorine (5kgs over three days) with two bottles of algaecide treatment after reading the SLAM article through a few times, but I've run out of dichlor and left with cal-hypo. Started shock on Saturday morning.
After seeing no improvement in the color of the water or the clarity improving, I finally opened the sand filter to inspect this afternoon to find that it is very dirty with leaves trapped into layers. There is no calcification present. The previous owner replaced sand 14months ago. The leaves are spine shaped from a nearby tree and seem to have passed right through the filter baskets unhindered due to the size and shape of the needle-like leave.
The pool cleaner and pool skimmer are in good working condition. No floating debris in the pool water or on the floor of the pool, fortunately.
Question time:
1) Should I try cleaning the filter sand by washing it or rather replacing it?
2) The pool agent suggested I try using Peroxide after the current FC & TC goes to zero to "try" and kill the algae. Is this a waste of money exercise if I've already tried such a high shock treatment?
Kind Regards,
Chris
My Pool
19K Gal (75K ltr), IG(20+years old), Plaster, 1hp motor, 350lb Sand filter, 1 Skimmer, 2 return jets. No filter pressure guage.
Filled from borehole and rainwater.
FC - 0.9 ppm
TC - 1.2 ppm
PH - 6.9
TA - 80
CH - 550
CYA - 55
Question time:
Kind Regards,
Chris
My Pool
