Just got my new 950VSP pump but having a hard time understanding how to wire it. In the old Hayward single speed pump there were 3 wires powering it. An Orange, blue'ish and green all 12awg. I simply removed that pump and connected the old 12awg wiring inside the 950 pump insides. Green to ground and then blue to L1 and Orange to L2. Then I connected both the blue and orange to the white buss bar inside the pro-logic assuming this would then provide the 240volts that I think the pump requires. Then, Inside the pump housing I changed the dip switches all to the OFF position. When I first opened the pump electrical housing it had a black plastic 4 wire connector connected to some pins. Black, Yellow, red and green. I removed that connector and used the supplied spare unused connector (in a bag inside of the pump motor) and I connected the supplied black and yellow wires to that plastic pin connector. Black low voltage on "A" and yellow wire on "B" inside the pump. Then, those 2 wires go up to the upper left corner inside the aqua logic pannel to the 4 pin "green" block that I believe says Remote display) with the black in 2 and yellow in the 3 position. It does not appear that my pump is getting any power though.
