Hello. Info first, trouble second maybe? Pool is in ground, plaster, 20,000 gallons, central florida, faces east / west so blasted with sun all day, no screen, hayward vsp pump and cartridge filter, fed with city water.
The issue started with copper staining the bottom of the pool. Used citric acid and was told that chlorine has to be 0 to do so. Got to 0, citric acid worked. In that short time at 0, green algae took over hard. Pool store said blast with chlorine and all will be good. Did so. Green algae went away. Black algae started to appear. Tested the water using the AccuBlue machine and it showed low chlorine so they advised keep putting more in. The black algae only grew larger, now going around the entire pool and 1 ft down.
Yesterday readings: FC 4.67 Total 5.24 pH7.4 Phosphates 3,751 (all other parameters are in line so no need to post)
Used Natural Chemistry Pro supposedly concentrated phos remover. Instructions for my volume and number were to use 8 ounces. Used 16.
Today readings: FC .39 Total .39 pH7.4 Phosphates 3,649 (all other parameters the same as before).
So is there any way possible to figure out what sort of chemical nightmare this is.....or is this doomed to be a skate park?
