so, as you can see, we’ve had problems for a while and finding a decent pool repair man in Bali is not easy. First assessment was done about a month before pandemic, two companies came out, tested with die, buckets, and tried to determine where leak was. No die was being drawn, they never clogged the main drain so I assume they didn’t think that’s where the leak was. Instead they sealed up 3 return valves with plastic caps and silicone. After the next day or two, they decided to permanently close off those outlets and reroute the outlet water to the other side of the pool. Never the less, that didn’t work.. the virus came, and the wife and I Decided not to let them come back. Since then, I have grouted and used cement to fill in large gaps around the edge of the pool, and today I just clogged the main drain and left a bucket of water. We don’t care what the pool looks like at this point because eventually we will remodel the house and the pool will be resurfaced with something. But we want the leak stopped for now. I’m waiting to see what happens in the next 24hrs. Question 1- can the water seep through the tile? I did an overkill with the grout although the tiles were installed without spacers. Some gaps, narrow and wide so on the spaces too thin I layered heavy grout and even cement mixed with damdex. (Recommended by last repair guy). 2. What is normally under a pool like this, plastic, some kind of coating? The first time I drained the pool, it seamed as though all the water that was leaking was coming out in a gap where the wall meets with the bottom. I used cement and damdex there. I grouted 3/4 of the pool before It rained. Still leaked. Drained it again , the one spot that had water coming out was stopped but there were a couple places where it seemed like water was coming up through the tile. After finishing grout and sealing everything, there was still a leak. Over night , looks to be an inch. That’s when I clogged the main drain and started a second bucket test. We are in tropics, 100% humidity, and it’s about to be rainy season. Super hot and sun beats on the pool. 3.If it’s the main drain, should we seal it? If we do, how do we circulate the water without pump and filter? 4.Can we resurface the whole pool with cement with sealer? And is there a paint, dye, or stain to color the cement? We have no idea when this pandemic will end here, until then, wife wants zero visitors. Especially since there is no way to the pool other than coming through the house. I hope this thread gives everyone an idea what our situation is and we gratefully Await and welcome any solutions or advice.
