Moved from here.
I'm having the same issue with flaking and cracking travertine pavers and it's been a 4 month nightmare. Everyday I notice small chunks or flakes (disintegration) around the pool deck. They are also cracking most likely because the compaction wasn't done correctly. The Contractor repeatedly says that travertine is an imperfect stone and the chipped corners/edges and flaking is completely normal. Aaargh!!! They did replace about 20 pavers last week and used PLAY SAND as the base and didn't compact it. Is there any solution to this or are they simply defective?
