Hello,
I am a brand new pool owner. We set up an above ground Coleman 18x48 metal frame vinyl pool on Saturday and started filling it from our well. I knew we had high iron so had done some research and used a Hydrolife Pool filter on the hose to try and filter some of it out and added two quarts of Metal Out while it was filling, it took a day and a half to fill completely. It did look decided yellow in the beginning, but after it got about halfway it took on a more aqua cast, but was otherwise clear. I'd been unable to find a decent test kit so had bought an HTC "opening kit" which included a few test strips and other chemicals. We put the HTC Shock pack (which said it included softeners and built-in clarifier) in and the water immediately turned cloudy, left the pump going all night. The next morning it looked clearer but more green, I did a test with the HTH strip and based on my best interpretation I had:
FC - 0
pH - somewhere between 7.8-8.4
TA - 240
CH - It gave a "total hardness" that I have been completely unable to determine because the color is lighter than the "ideal" and "high" ranges but nothing like the color of the low range so guessing maybe on the high side
CYA - looked to be right in the middle of the ideal range so about 55-60
I was shocked at the 0 chlorine so started researching. Went and bought some liquid chlorine 10% and 20% Muriatic Acid. Added 26oz of the MA and my PH seemed to go down to 7.5-7.8 so an hour later I added 40oz of the chlorine. The pool did get much clearer looking though still green-ish but my levels seemed to come within acceptable (barely) so I let the kids swim in it, and checked again that night and chlorine back to 0. I found this site and decided to try the SLAM. Using the Pool Math calculator and my best guestimate with the stupid test strips I added 18oz MA and 136oz chlorine. This morning my results were:
FC - 10
pH - 8.4
TA - 240
CH - still no idea
CYA - looked like 70
I tried texting the strip to the HTH text number hoping for some numbers but all I got was that my chlorine was high and don't get in until it comes down and TA was really high and to add 18lbs of their PH decreaser! That totally threw me because it didn't even seem to be close to equivalent what the MA suggestion from the pool calculator was. I put in another 20oz of MA, waited and hour tested, it was the same 8.4 for just added another 26oz MA. Not sure if I should chlorinate or not.
I've got so much going on and this seems to be taking all my time, I'm supposed to be getting ready for my parents to arrive tomorrow and all I've done is pool the house is a mess! I live in the country so there is no place to get a good test kit (or any other supplies, I haven't been able to get a brush pole either) and the soonest I can get one from online is early July, my parents are coming from FL so I'm going to see if they have time to get me the recommended Taylor K-2006 one. To complicate things we'll be out of the town for 5 days starting Saturday, so I'm not even sure I can get this pool in shape by then, and even if I do what then? Is it all going to become undone while we're gone? If there something I can do to simply keep it from getting worse while I get the supplies and need and the time to do it right? I was frustrated when we bought the pool at what a hard time I was having to find information about taking care of it, and now I'm even more frustrated. I did not realize it would be this complicated, I wish I'd been better prepared.
FC - 0
TA - 240
FC - 10
pH - 8.4
TA - 240
CH - still no idea
