pH is in the acceptable range. Leave it. TA is also fine. When the pH needs adjusting, the TA will also get reduced. CH is fine for a vinyl pool. Zero is the ideal for CC. Up to .5 is okay.Ok, redid it this morning. I had made a mistake when doing the TA test last night, so my TA isn't so bad. Yay! My calcium came out better too, the light was starting to fade and I think that affected what I was seeing. Here are my numbers this morning. the Pool Math calculator says to add 2.7oz of muriatic acid, so I'll do that. It's also suggesting to add calcium, but I think I'd like to wait a bit and do the test again before I do that.
FC - 5
CC - 0
PH - 7.6
TA - 120
CH - 90
CYA - 50
Question: What am I going for with Combined Chlorine?
Those are good numbers, just monitor your PH for rise. You can lower it to a target PH/7.4 when it is PH/7.8/8 (vinyl does not do well with low PH, it weakens it).Ok, redid it this morning. I had made a mistake when doing the TA test last night, so my TA isn't so bad. Yay! My calcium came out better too, the light was starting to fade and I think that affected what I was seeing. Here are my numbers this morning. the Pool Math calculator says to add 2.7oz of muriatic acid, so I'll do that.
PH - 7.6
TA - 120
You have a vinyl poolIt's also suggesting to add calcium, but I think I'd like to wait a bit and do the test again before I do that.
CH - 90
CC = zero! You hope to not have these show up. But usually only have to be concerned if you have multiple readings of +1.Question: What am I going for with Combined Chlorine?
FC - 5
CC - 0
CYA - 50
The best advice I've heard all day!In short: stop messing with the chemistry and go swimming. Unless you want to wait for the rust to filter out.
Richard, how would the iron separate out? From being heated under the cover? My concern about SLAM is that it will turn the water all brown the sides will be completely stained, maybe it's the lesser of evils though? You're saying definitely don't run the pump though? I suppose I could get some of those floaters with the pucks, but I wouldn't have idea one right now how many, etc and maybe they wouldn't circulate the trichlor without the pump going. Sorry, I've got so much going on my brain has turned to mush!Raise FC up high (no more than SLAM) and put the cover on. Without any sun, you won't lose any there and you may find all the iron precipitated out so you can just vacuum it up.
