Tips on how to clean intelliPH acid injection fitting ?
tomas21
234
California
Pentair Intellichlor IC-60
Noticed that my intelliph reservoir isn’t lowering much. Tested the outlet hose and it is pumping nicely. My guess is there is some clog in the acid injection fitting since not being in use during the offseason. Any tips to clean the unit out if there is a clog or blockage ? Otherwise will just order another injector fitting.
Short version: You replace it periodically.
Reactions: tomas21
Wonder the different between the Stenner injector side inside plumbing that has a nozzle like tip vs. wide open Pentair
Stenner - UCDBINJ Injection Check Valve 1/4-Inch Pentair Injection Check Valve For IntellipH and IntelliChem Control Systems | 522513Z
View attachment 642666View attachment 642667
I found there to be little to no difference in the function of the two
