I recently installed a Hayward MaxFlo variable speed pump so I am no longer using my Intermatic T104P201 mechanical timer to control my pump. The Intermatic timer has a fireman's switch that I had been using to control my Raypak natural gas heater.
I was planning to continue using the Intermatic timer to control the heater via the fireman's switch with my new pump installed, but I realized that the Intermatic timer only opens the fireman's switch for some short period of time before the main switch turns off. I had thought that as long as the main switch was off on the Intermatic timer that the fireman's switch would also be open, but this is not the case.
So, if I want to use the fireman's switch to control the heater I would need to very precisely synchronize the Intermatic timer with my variable speed pump's built-in timer, which I think is too tricky/risky to do.
My questions are:
1. Is it possible to control power to my 110V heater with the Intermatic T104P201? This is a DPST timer, but it maybe has a spot to hook up a neutral wire?
2. Are there any simple digital, low voltage timers that I could hook up my fireman's switch to? I believe the wire from the heater for the fireman's switch supplies 24V. I like the idea of controlling the heater through the fireman's switch so that I am not completely powering off the heater.
My questions are:
