Timer for 2-Speed Pump??
jobondur
182
Virginia Beach, VA
@JamesW - couldn't I do this all with just two timers, one 104 and one 106. I'd hook up the pump the way the diagram is shown above. But then for the Polaris, I'd run the common from terminal 4 of the 104 to the Polaris as well and then connect the Polaris to terminal 3 of the 106. That would make it so the Polaris turned on at the same time as the pump switched to high setting. Correct?
JamesW
23,932
What breakers feed the timers?
How many amps does each pump need?
Does the booster pump get power from the pump timer load terminals?
JamesW
23,932
You can do it like that as long as you're not overloading the breaker.
You can remove the booster timer mechanism and insert the T106 timer mechanism in the existing box and then rewire.
Also, note that the T106 clock mechanism has to be connected to the same terminals as the T104 clock mechanism.
jobondur
182
Virginia Beach, VA
All my pool equipment is on one large double breaker (not sure of amps - at work) and I've never had an issue tripping the breaker.
From memory (which sucks) the current setup is - power from timer A (controls pump) flows to timer B (controls Polaris). Obviously the clocks for both are always powered.
If I did it this way, I might also insert a manual light-type switch in between the timer and Polaris in case I don't want it operating for some reason
jobondur
182
Virginia Beach, VA
Just playing with options for now. I may want to wait until my father in law comes to town to wire this all up. He's not quite an electrician, but about as close as you can get to it without actually being one. I just need to determine what to have on hand when he gets here.
