Going into the 3rd summer of ownership of a pool. I think the original owner just signed on the dotted line and move forward. Our electricity bill is constantly high and I believe the route-cause is the pump.
Net:Net I have it in my mind to change out the pump. The pool is ~13,000-14,000 gallon with a 2" suction line from the skimmer and/or main drain with. Currently a single speed Jandy 1.5 pump and a Jandy CL460 Filter. I do have feature valves like a water fall (seldom used) and bubble jets (never used). Currently the pump is set to run around 6hrs to run through a full cycle.
Main goal is to safe on electricity as much as possible. The pump is close one edge of the pool, maybe within 30ft -
Thoughts on the Pentair 011018 IntelliFlo Variable Speed and is it worth it over the Superflo Vs? What am I not thinking about?
Thanks in advance for the assist.
