We've struggled with our FC and TA. I was taking care of the pool this fall and this spring got busy and wife paid a local guy. I'm now trying to get everything back in check and have decided I need to drain it. Current test results from 5 minutes ago:
Using K-2006
FC - I can't even get it to turn pink after 6 scoops at 25 mL
PH - 7.0-7.2
TA - 70
CH - 500
CYA - clouded up almost instantly. I would estimate it from 700-1000
I tried inputting the numbers in the app and had all sort of issues; but it appears draining and replacing with fresh water is the solution.
I use liquid bleach and muratic acid when needed. I have NOT shocked the pool this year. We've had some crazy weather though.
I'm going to go ahead and drain 75% of the pool. Looking for any advice or guidance once I refill it with new water.
Thanks in advance.
Using K-2006
PH - 7.0-7.2
TA - 70
CH - 500
Thanks in advance.
