Tight strainer lid .. any advice?
TexasBR
121
Houston, TX
The lid of the strainer basket on my Hayward Tristar single-speed 2hp pump is very tight.
Any advice on how to open it safely and without superhuman strength?
Also, any advice on how to prevent this from happening again?
Many Thanks!
Tap on the ears (gently) with a rubber mallet to loosen it.
Did you tighten it by hand?
If you don't have enough strength to securely close the lid with your hands then use on or two taps of the mallet. As little as necessary.
Reactions: JamesW
Any pool or plumbers silicone based lube would be appropriate. Source from a big box, hardware or pool store. You want to stay away from anything petroleum based as it will degrade the rubber.
Reactions: TexasBR
