I disassembled my power unit because the cord connection was loose and it has to be tightened with the plastic nut that is threaded on the inside of the unit. When I pulled apart the case the thin ribbon strip that connects the quick clean red light and full cycle button with yellow light to the electronic board came off before I could see which pins it connected to. There are 7 pins in a row on the board, but the connecting ribbon only has a 4 pin female connection. Anyone know which pins its supposed to go to?
