At least it's not a dinky florida filter where the average cartridge is only 0.00694444 square feet.Well, keep in mind this is Texas, so ...
Jim R.
Rats!! You’re all correct. I could cryOften when we see cartridges bulging out like that, it means the filter has been plumbed backwards. Show us a photo of the pump, filter, and the plumbing that runs between them.
This actually made me lolJames,
Maybe a picture of a pickup truck driving away from you on the input line, and a pickup truck driving at you on the return line, would have been better. Would not require the installer to be able to read...
Jim R.
they already came out and replaced the cartridges, just yesterday. They are coming out tomorrow to replumb but I’m not sure if will need new cartridges again. We’ve been running the filter for the last 24 hours so I guess we’ll see how badly they’re damagedThe builder needs to come out and fix this including new cartridges,
The pool is only a few months old, I just noticed it wasn’t filtering very well so we decided to take it apart and change them out and that’s when we saw the damage. We sent them a picture of the filters and they came out and changed them, they thought it might’ve happened when they were priming the pump and the filter got back pressure (They had a very hard time priming the pump, it took like two days). Then y’all posted your pictures and my husband and I went out and checked and sure enough it’s plumbed backwards. I contacted them and they said they’d be out tomorrow to fix itYou would hope that after the cartridges failed multiple times, the builder would take a few minutes to try to figure out what might have caused the problem.
The plumber is busy working on a new job.
Seems like maybe a problem in the suction lines.They had a very hard time priming the pump, it took like two days
My husband says they got that part right, because everything’s coming out the right way. He says he thinks they had a missing O-ring on the intake to the pump and were sucking air and that’s why they had such a hard time priming it (their official reason was they thought there was a blockage from plaster in the pipes).Seems like maybe a problem in the suction lines.
Maybe they got the suctions and returns backwards?
