- May 3, 2014
- 62,902
- Fiberglass
- Pentair Intellichlor IC-40
Your CH is low and most likely your salt level is low as you do not have a SWCG. And you say the water temperature of the pool water and fill water are nearly the same.
Put the pump in the deep end and fill from the shallow end if your fill water is nearly the same temperature as the pool water, you have a saltwater pool, or have very high CH. Put the fill hose in the skimmer, if you have one, in the shallow end. If no skimmer, then use a bucket to put the water hose in and have the top of the bucket above the pool water surface. Be sure to secure the hose to the bucket.
You said you do not have a skimmer in the shallow end. So, you put the fill hose in a bucket with the bucket at the top step so the water you add is not overly disturbing the surface.
Balance the in and out flow rates.
