I'm curious, heugeneo has there been any direct sun on your pool when running the chlorine so low?
I'm a little scared of having an algae bloom when I get the chlorine down to apply the cya reducer in the upcoming week.
But I think they claim that won't be a problem.
Yes, the automatic cover has been open the entire time, and there is no shade. I too am concerned about an aglae bloom, however the manufacturer states that will not happen while their product is in (we'll find out). If chlorine is raised about 5ppm it will kill all their product. I bought some polyquat 60 I was planning on using, but haven't yet as they don't recommend any other product be added while the bioactive is used. It's coming up on a week with almost no chlorine. My thoughts are if I have an algae bloom I'm going to have to dump a ton of chlorine in there anyways, so I might as well give the bioactive all the chance it can get in the mean time. I did add some metal sequestrant the other day as I noticed metal stains starting to return. I don't know if that had an effect on the bioactive or not.
Looking forward to hearing if you have good results!
Readings today, not quite 24 hours after second dose:
FC .2
CC .6
CYA 4:1 dilution 250, 3:1 dilution 220
