I have been maintaining my AZ pool with liquid chlorine for the last 5 years and had clear water for the most part. However, I have been constantly fighting a high pH and am now seeing quite a bit of scale buildup so had my water tested at the local store to see what TDS levels were to evaluate if I should refill.
The TDS came in at 4100ppm and the CH at 209ppm. The pool store recommendation was to refill as there was 'no more room' in the water for the chemicals to act and it would be cheaper to drain and start over again. Reading a few threads here seems to contradict that view so now confused as to how to proceed i.e. drain or no drain. Suggestions?
