As the title says, this pool refuses to clear up. For reference, I am a new pool owner and I have done months of research before attempting this. I purchased a home with an above ground pool that hasn't been opened in years. I've been working on this project fora month now and the filter and pump have been running 24/7 (except during the 24hour period I had to use flocculant).Over these last 4 weeks, the water went from dark green to green/blue, then to a cloudy blue, then now to a hazy teal-blue. I can only see about 2 feet of the pool. I still cannot see the bottom of the pool. I've used clarifiers (being careful to not overdose), I've had to use flocculant to remove the tremendous amounts of dead algae (this brought the pool to a hazy blue). I've balanced the pool daily with a test kit and done the SLAM process. However, this pool just refuses to clear up and it is very frustrating at this point. I'm now reading on how there should be 3:1 ratio between calcium hardness and alkalinity. I don't know what to do anymore. At this point, the microparticles don't get caught in the sand filter as the pressure doesn't rise anymore/water conditions don't change. The clarifier seems to not work anymore. I tried a filter enhancer (cellulose) and it just clogs the filter immediately, even if I use 1/4 of the recommended dose. I just don't get it. Please help... thank you
24' pool, 4' deep ~12,000 gallons
23" sand filter, 1 1/2 HP pump
FC 7.5
CC 0.2
pH 7.5
TA 77
CYA 41
CH 114
FC 7.5
CC 0.2
pH 7.5
TA 77
CYA 41
CH 114
