- Feb 6, 2015
- 7,863
- Plaster
- CircuPool RJ-45 Plus
You are going to be starting up the SWG very soon. This will cause your pH to rise quicker that it does now. Lowering the TA a bit quicker will help slow the pH rise.
I thought you would shoot for a little lower than 7.5 (and a CSI barely 3/100 lower than zero). It's time to be more agressive about lowering your TA to about 60. Lower pH to 7.2, let rise to 7.5 - lower to 7.2... etc etc - until TA is in the 60-70 range... then let pH rise to 7.7-7.8 and check all levels again.
Again - for CSI - NOT as close to zero as possible....within the RANGE of 0 to -0.30 (zero to negative 3/10 - negative 30/100).
I'm not in a hurry to lower my TA cause I don't have a SWG which will cause my pH to rise. And I also check my water a bit more often than you do (one of the luxuries of being retired and not having little ones under foot on a daily basis).
You need to add 38oz of granular stabilizer to get to CYA 70.
10 oz will only raise the CYA by about 5. Certainly not enough.....
Ain't none of us going down in the quicksand.. now go dose the pool as suggested.
