messed up today. i was so busy and out of town for soccer tournament... then started checking into salt cell and distracted by grumpy husband upset about salt cell and I didn't check measurements until now. This is a typical thing that happens to me. Can't wait to get salt back up and running so i can have a little more slack. So, I went under FC but I'm hopeful it'll be ok.
measured 8pm:
FC=3
CC=0
pH-7.8 (I think)-hard to see well at night. i tried several lights in the house and put a white paper around it.
TA=130 from 4-28
CH=300 from 4-28
CYA=30 from 4-28-will check tomorrow
salt=2400 (estimate)/was 2000 on 4-27 before adding 40 lbs-will check tomorrow
temp-79
csi .19
added 1/2 gallon chlorine immediately.
added 20 oz acid with the attempt to get CSI to -.1
will recheck salt tomorrow
yes, I have the strap wrench (i looked it up to confirm it's the same thing) which I don't like at all since I always forget how to do it and I think the other thing we use is a plumbing wrench.
sorry, i didn't see that u previously told me the same thing Leslies told me about the O ring and hand tightening the salt cell. we already broke the union (?) once. it would've been nice for the pool company to tell us to not use a wrench or tighten too much or notice that it didn't have an O ring. we'll see how this goes as i sent an email earlier and they are coming this week with a new pressure gauge that was leaking. warranty on most things ends in June so if there r any other things anyone can think of that i might need to have checked out that'd be great. thx!
as far as the 0000 salt I can't find it saying that anymore no matter where I go on the panel. What is shows on when i go and look at it is:
chlorinator off
test salt level
check system-very low salt
check system light is on.
i think there was a piece of calcium stuck in it when i put in back on after cleaning with acid twice for a total of 40 min or so when i emptied the water. i tried to get it out with a knife but it wasn't reachable as I'd need a tool that is curved. also i was told here not to stick anything in there so i'm stuck with the calcium since i'm also not supposed to soak it too long (and i did add like 50% acid/50% water at one point but still can't get that piece off.
My Pentair SWG reads zero salt (even with 3200ppm in the pool), when the flow rate is too low. Since it reads salt only once at startup, subsequent flow adjustments won't fix the zero-salt reading, I have to power it down then back up again to force it to retest salt at the adjusted flow rate.
I don't know the Hayward SWG at all, but could this be a flow issue and not a salt issue? I've skipped some posts of your thread, so forgive if this has been covered. I know you've been struggling with your SWG. How have you determined it's getting the amount of flow it needs to function properly?
it does say there is flow. that's all i know about that. also, i have to go back and reread how to reset it each time since it's not self explanatory. i think i have to press the + sign when it's saying "check system." i'll go try that now
