Hi everyone. We built a new house up here in the Menlo park CA part of the SF Bay area a couple years ago. It has a 20x50 pool, with a cover, and is heated by a 450,000 BTU gas heater. The family loves to swim year round, and my wife and daughter especially love to swim (she's on a local swim team), but like the temperature at 85-89 degrees. This results in a pretty big gas bill, > $700/month. This is almost certainly driven by the pool, as the house heating is all done by heat pumps, and there is a very high efficiency condensing hot water heater that works extremely well, so I think the pool is most of that.
Our PG&E pricing for electricity is rapacious (0.19/kWH off peak, and 0.51/kWH peak), but they also have been hiking gas prices, and with the push to punish people for using gas, I think it's only going to get worse. Most of our gas usage is in the tier 2 price at $2.41/therm.
We maxed out solar panel installation, and have about 27 kW of generation on the roof of the house, garage and poolhouse, and overall generates about 100 kWH (average over a year) of solar a day. Of course in PG&E land, excess solar gets sold to PGE for $0.03/kWH off peak, and $0.07/kWH peak. So I was thinking that we could reduce our gas heating if we used a solar pool heat pump in addition to the gas heat. We'd keep the spa on gas, but the main pool could be heated offpeak, and especially used during the time when the solar is being generated, as PG&E doesn't pay us much for that energy.
Weather here is pretty mild even in winter, so a heat pump would have pretty good efficiency here. I wish I could have tied it in to the home heatpump systems so that it could heat the pool with the heat being removed during air conditioning, but there aren't really systems that can do that at the residential (ie single phase power) level.
This would be messy from a control POV, as you would want the heat pump to run the bulk of the time, and use the gas heater to boost it when it couldn't close the gap adequately. The pool is controlled by a Pentair Intellicenter system, but I am a software engineer and have a great Home Assistant system integrated, as well as a RpI running the nodejs-poolcontroller package, so I think I can probably make the controls part work.
Would it work to plumb the heat pump in BEFORE the gas heater in series, or would a separate pump etc... be need?
It would be nice to cut back on the gas bill, especially if I can lever some of the "cheap" kWH that are available to heat the pool inside of PGE paying a minimal amount for them.
Has anyone done this before? Am I crazy for thinking about this idea?
thanks!
Mike
thanks!
Mike
