Thinking about a solar heater
Meaty
75
South West Florida
I was thinking of getting a solar heater - something like the blue wave solar curve - to hook up to my existing pump/in ground pool. Does anyone
1) have experience with this heater? Are other solar options preferable?
2) know a reputable installer in the north Dallas area
thanks!
thanks!
The Blue Wave is only about 8 square feet of surface area, you will need 8-10 of them to really gain any heat.
Solar panels are all about surface area. I have 72 square feet of Sungrabber panels, (and plan to add another 24-48 square feet) and only gain a few degrees on a bright sunny day.
I have fafco solar bear panels. It's my first year with them and I've been happy. I bought two from Amazon for my above ground pool since putting the solar cover on was a pain with my setup.
Fafco Solar Bear Economy Heating System for Above-Ground Pools Amazon.com : Fafco Solar Bear Economy Heating System for Above-Ground Pools : Swimming Pool Solar Heaters : Patio, Lawn Garden
When I was starting out my research I found this site a good intro to the options out there.
Best Solar Pool Heater Reviews Ratings For 2016
Good luck.
The University of Central Florida collects solar pool data, tests nearly every panel manufacturer and publishes the solar heater data online. It's a great resource here: For Pools
We chose to use iSwim panels and they have been great. To your point, installer experience is very important, as is their familiarity with your pool system and automation.
As the others have said pool solar heating panels is all about surface area, all of the small panels that claim they will heat a pool are lying. For climates like ours basic unglazed black "plastic" panels work best, in fact under ideal conditions if the daytime air temperature is within about 20 degrees of the pool temperature they can approach 90% efficiency. Meaning 90% of possible heat from the sun is transferred into the water in the panel. As to the UF test results, you will find most panels are within about a 10% performance margin of each other, and that these tests are under set conditions. In the real world there are factors like wind that may allow a poorly rated flat panel under lab conditions to out perform a higher rated rippled panel, as the ripped designs do better at absorbing sunlight throughout the day if they are installed at the correct angle, vs flat panels which loose less heat to the wind.
Ike
p.s. I have a DIY install of the Techno-Solis panels (the Vortex panels mentioned above are a private label version of the Techno-Solis panels, so identical except for warranty issues, mounting brackets, and also the genuine Techno-Solis are offered in more sizes and both 1.5 and 2 inch headers, vs only 1.5 inch headers for the Vortex)
