Flying Tivo
- Jan 24, 2017
- 2,966
- Plaster
- Pentair Intellichlor IC-40
I would not add the fiber until you are well underway with the SLAM, at leas 4-5 days in.
Quandary: whether it makes sense to stop the pump for even a few hours in the midst of a SLAM.
I did stop it overnight, and there was some settling. I vacuumed to waste. Didn't seem to make much difference. I suppose I would need to do this repeatedly.
Correct.I decided that Recirculate mode means circulate without filtering.
You should be able to get away with it. If the pool water gets a bit cloudy when you start the pump, raise your FC up to near SLAM.Is there any harm to leaving the pump OFF for up to 36 hours to let the particles settle, so long as the FC is reading 11.5 to 12?
