Hi there - first poster here. Incredible forum - thx so much to the brains out there contributing! Have been reading up voraciously to educated myself as I am in the process of having my first pool built - which is still a few months away from completion.
I'm currently finalizing design and specs w/PB and need to understand chlorine generation capacity of SWG. The one PB recommends is Jandy AcquaPure 1400, which is rated for a 40k gallon pool and supposedly produces 1.25lbs/day of chlorine.
Now, the pool I'll get will likely be around 17,500 gallons. If I get the math right, this equals ~148,000 lbs of water. If, as I understand, 1 ppm of chlorine equals 1 lbs of chlorine in 1,000,000 lbs of water, this would seem to suggest that:
(i) in my case, 1 ppm of chlorine equals ~0.148 lbs (or ~2.4 oz) of chlorine;
(ii) if I want to target, say, 6 ppm of chlorine in my water starting from zero, I would need to add 0.888 lbs (or ~14.2 oz) of chlorine in my pool; and
(iii) once I reach my 6 ppm target, and assuming that I have no algae and my only FC loss is due to UV exposure and that I am losing, say, 2 ppm daily based on that sun exposure, THEN it would seem that my SWG would need to replace/produce only 2 ppm daily which in my case is ~0.3 lbs of chlorine.
(btw I know the numbers are fictitious, but pls play along - I just want to understand if I am getting the math right here).
When the SWG specs say it is rated for 1.25 lbs of chlorine production per 24hrs, what exactly does that mean? Is it assuming that the SWG is set to run at 100% capacity 24hrs/day? If so, would it logically follow that I would get that SWG to produce my needed 0.3 lbs of chlorine by:
(a) running it 24hrs/day at 25% capacity (since 25% of 1.25 lbs is ~0.3 lbs); or
(b) running it 6hrs/day at 100% capacity (since at 100% capacity it produces 1.25 lbs or 0.052 lbs per hour, and 0.052 x 6hrs = 0.3 lbs of chlorine).
To me, (a) or (b) should be equal in terms of chlorination and both meet my requirements in this example. Is this correct? And if so, is there a difference between (a) and (b) in terms of life shelf of the SWG (running it constantly at lower power vs. shorter runs at full power)?
Thx so much for your help validating my thoughts
