Yes, do! "TW doesn't go in the pool" so I wanna see this!
Haha, ok I'll do it when I get home. Does sitting on the ledge in the kiddie pool count as "getting in?"
Yes, I want to bring it down slightly to see if along with daily brushing (concentrating on small portions at a time) it will help lighten the scaling "stains". So its ok to bring it down to 7.2?The acceptable range for the CSI is between -0.6 and +0.6. You are at +0.06. That's a long way from worrying about scaling. Like ten times your current test result. If you do want to keep it slightly on the negative side of zero (due to your past scaling), then yes bring the pH down.
I don't think its meant to be. imgur is doing something strange. It uploads the image ok but then the options to the right are images of the day (or something like that). Have you come across that? How do I bypass?Sure!
I looked at the product but couldn't discern if it was useful for calcium scaling. What do you think?Ok. So lowering your CSI just less than 0 really isn't going to get you very far. You won't see any serious calcium etching until you get below -0.6 but in order to do that you'll have to drop your pH and TA quite a bit. Also, everything with calcium in it, good and bad plaster alike, will be etching.
Why not consider a tool like the Purity Pools Spot Stain Remover?
Something like that will allow you to get concentrated acid (dilute the MA like 4:1 water:acid) directly on the spot without dropping the entire pool's pH.
I have never used this product before and have no relation to the product manufacturer but I saw it once and thought it was a neat idea for getting concentrated stain removers right to the affected area.
Just my $0.02 opinion.
It seems like it will take me til 2020 to do the entire pool since there's so much, but it would be worth it if it got it cleaned up.
Sure!
That is TOO FUNNY!! YES!! Amputate the toe!!!!! (Kidding)I think it would work fine. You load the tube up with diluted MA (while over the pool water) and then rub it on the spots. Sure, it's not a wide area and it would take a long time to do a big scale patch, but it's got a much better chance at being effective than trying to turn your entire pool into an acid bath. It also allows you to concentrate your cleaning effort to an exact area.
Think of it this way - what if you do the acid bath thing and you lighten up 80% of the stains. Are you going to keep going to get the last 20% and risk damaging the rest of the plaster? Remember, when drop the TA and pH to lower the CSI, every plaster surface, good and bad, is exposed to potentially corrosive water. Does a surgeon amputate your toe to remove a ingrown toenail or does he target his excision to treat the affected area?
Thank you, but how do I get it on my avatar?Awesome picture!! I like my pool but I like it a lot better when my kids are in it with me!
OK, I'm ordering it, gonna try it. Will report back
Awwww, Thanks! I don't know what impresses me most about the pic. You, your grandbaby, or that sparkly pool. Great photo!!!
Yes, its 10X10 pixels but thats greek to me.Avatar pictures have file size limits. You'll have to edit the picture on your computer and shrink it down to size. I believe there's instructions for avatar picture sizes.
Option 2 - Upload Image From Your Computer:
Note: The maximum size of your custom image is 100 by 100 pixels or 6.0 KB (whichever is smaller).
Right???? I gotta go with the grandbaby....all the way!!
But thank you for the praise of the pool, the pic sure did make it look real sparkly! (Can't see the scale unless you're a TFP member).
Oops yes, 100X100. Can I do it on an ipad?The standard Windows image editor on any PC will allow you to open that picture up and convert the size of the original picture down to 100x100 pixels. Then you save it as a new file and use the TFP website to upload it as your avatar.
