- May 23, 2015
- 24,472
- Plaster
- Pentair Intellichlor IC-60
UPDATE: Second fire breaks out at Lonza chemical warehouse in Bradley County - WRCBtv.com | Chattanooga News, Weather Sports
While I certainly advocate the use of cal-hypo when it can be substituted for liquid chlorine, it is a good reminder to treat it carefully. Cal-hypo can come in several different concentrations (% available chlorine) with 74% often easily obtainable. The downside to cal-hypo is that it emits chlorine vapors even in dry form and those fumes can act as a source of oxidation which can cause fires if flammable substances are stored near it. There are plenty of documented reports of cal-hypo fires happening but we rarely hear about them. Of particular concern to me is that people will use cal-hypo but not use it appropriately and open themselves up to exposure. Most cal-hypo for retail consumer use is sold as 1-lb bags of dry powder (and the bags are perforated so that they can breathe/emit chlorine fumes). If you use cal-hypo, the correct way to use it is to use an entire package and not leave any opened but partially used packages lying around. Doing that is a recipe for disaster.
So, if you plan to use cal-hypo in your pool this season, please do so safely by following all labelled package instructions. Also, make sure you store any cal-hypo in a safe location where it can not easily get wet and keep it stored away from any flammable substances.
