- Jul 17, 2019
- 3,730
- Plaster
- Pentair Intellichlor IC-40
So... yesterday after cutting the grass for the first time and kicking up a ton of dormant bermuda grass dust into the pool, I decided to backwash once the skimmer did its job and sucked up all of said dust. After dinner I went out and kicked the pool into service mode, turned the multi-valve to backwash, then fired up the pump to begin the process just like I have done many times in the past.
This time when I turned on the pump the pipe that takes the backwash water underground and to the sewer split. From what I could tell it cracked at the elbow in the pipe and then the long pipe split lengthwise right before my eyes.
It should be a pretty straightforward fix of the PVC, but I'm really confused as to why this occurred. Do you think it could be some sort of blockage in the line that caused the split? Should I try and snake the line before the repair? Maybe there was water in the line and a freeze got it? Anyone have any ideas on why and what I need to do other than fix the PVC?
