Is there a test kit for a salt water pool other than the TF100? If not, what's the recommended method for testing salt concern? I had some test strips in the past but I found them inaccurate.
To be clear... You really need both... the TF-100 is for all the other pool water tests that you need to do... FC, CC, pH, TA, CH CYA... The Taylor K-1766 is only used to test the actual salt level in the water..
