- Jul 6, 2022
- 21
- Vinyl
- Hayward Aqua Rite (T-15)
Currently in a SLAM and noticing some of my FC results seem inconsistent. I had done three chlorine tests and got FCs of 11.5, 7.0, and 8.5. The 2nd test was after 30 minutes on the same sample of water that had been on the counter, (I did that test slower than normal too), and the 3rd test was on a fresh sample of water (nothing added/changed).
Next day I did 4 tests right in a row just to check for repeatability on the same water sample. Three of the tests were within +/-.5FC, however one result (again the first test) was 3.0FC higher than the average of the rest.
Following day I did two tests and got 12.0 and 10.0 FC, done back to back on same water sample and tried to be as consistent as possible. Again the first test was the highest one, which seems to be happening a lot for some reason.
I did some searching and saw recommendations to move through the test as quickly as reasonable. I also have their magnet stirrer device (got with the kit) in hopes of being accurate. I am wondering if there is anything that can affect these tests or cause variations like this. These are the only things that I can think of that might have varied in my back to back tests:
The stated tolerance for the test is +/- 1 drop (0.5 FC) or 10% above 10 drops. Basically I’m trying to make sure I am doing everything I can to test carefully and consistently to get the best results I can, and if there are any common mistakes or things that are known to throw the results off I need to avoid.
edit: submitted before I was done, fixed post.
- The amount of the powder, instructions are pretty nonspecific on that; “heaping spoonful” and says it isn’t critical. On their website it says you can instead use two level spoonfuls (not sure if that was roughly the same or gives you extra). I read you may need to add extra powder for higher FC levels to ensure the test is accurate, so I was wondering if there was any more advice on that.
- How quickly you add the drops to the sample. I've been trying to stick to ~1 per sec as recommended, but I used to go faster at first when I knew a lot of drops were needed.
- Stir tube being dry/wet. I was rinsing at the sink, so I don't know if residual tap water left in the tube could affect the reading on later tests. I have started “swishing” some pool water in the tube after rinsing to try to get the tap water out.
- Freshness/temperature of the sample. If I test right from the pool or get a cup of water and test 30 minutes later, etc.
